Things we need.
-Sand Paper (80 grit, 800 grit, 2000 grit). RS:20 per piece.
-Filler Putty (Steel potein). RS:90 for small box.
-Aerosol Spray Paint (I used silver). RS:120 per can.
-Aerosol Spray Primer (I used grey). RS:120 per can.
-Aerosol Spray Acrylic Lacquer. RS:170 high quality can.
-Two Steel Spreading blade. RS:10 per blade.
-Microfiber Cloth. RS:200.
-Compound. RS:50.
-Masking tape and some newspaper.
-Wax. Use any.
After sading bumper with 180grit sandpaper and filling potien.
After wet sanding the whole bumper with 180grit paper.
Than, used 800 grit paper for removing the scratches caused by 180 grit paper.
Although, the primer need to be sprayed on the putty and damaged area but i did it completely.
After this smoothen the surface with 800 grit wet sanding.
After wet sanding the primer with 800 grit paper i have applied the silver paint coat (3 thin coats) after each interval of 10minutes.
After applying paint i waited for 10 mins and sprayed the acrylic lacquers (3 thin coats).
And let it dry over night.
The next morning, I used 800 grit for wet sanding very lightly and than used 2000 grit for very lightly wet sanding using soapy water.
Next i applied the compound with microfiber cloth. and than waxed.
NOTE: As it was my first attempt, In my case the results were good but only thing was lacking that i applied thick coats of paint which resulted to uneven paint surface and spots. You must spray very thin layers.
