Tutorial Included Below
Let's begin.
I am not responsible if you screw anything over.This tutorial is for educational purposes only and should be taken as such. I am merely providing a guide. There is no guarantee that you will do your retrofit as good/bad as I did. Proceed with caution.
Caution:
When installing HID's on your car it is good practice to disconnect the negative terminal of the battery to prevent accidentally shorting out anything or worse getting zapped. Be careful and observe safety.
Tools Required:
Screwdriver.
Spanner (Usually found in the toolkit of your car. Size may vary)
Hairdryer. (A heat gun or an oven can be used but this is the safest method. It takes longer to open the headlights but chances of melting them are reduced)
Spare headlamps (Optional. If you are willing to open your original headlights like I did then no need to get these)
Electrical Tape
Needle nose pliers
Patience (Most important. It took a total of 12 hours to get this done, be patient)
Tips:
Have someone assist you to prevent suicidal thoughts. No seriously, a second set of hands will be very useful when opening the headlamps. More on that later.
Begin by removing the bumper. This is specifically for the Honda City so keep that in mind if working on a different car. Remove the 4 clips. Then the 2 screws in the wheels well.
Gently lift the grill and pull toward yourself. The bumper is snapped in place and should be very easy to take out.
Next remove the 4 bolts holding the headlamp to the body. The headlamps have a metal frame attached to them that holds the bumper in place. You will have to remove the frame to open the headlamps. It is held in place by a single bolt.
Here is what your car should look like if you did everything correctly. Keep in mind that you do not need to remove the engine splash guard.
The Projectors + 4 CCFLS + Wiring Harness + 2 H1 Bulbs = 11000 PKR
Ballasts = 3000 PKR
