If u have a socket set at home then try all size sockets.I think it's 14 number.One nut is for drain and other is for fill.Fill the gearbox until fluid starts dripping out.Also replace both nut,s washers just to be safe.Because faulty washer can cause leakage issue.And some mechanics will trick u into believing ur seal is leaking.
