Though there is always an option of 12 volt adapters for vehicles to be used in cigarette lighter for charging mobiles n tabs but just for a better look I decided to create a USB power socket for my car.
Step 1: Disassemble USB 12V car charger for mobile.I disassembled a 12V USB car charger with 1amp and 2.1amp usb ports and removed the circuit board from the plastic casing.
Step 2: Preparing the coverThen I cut a piece of plastic equal to the size of the port where this socket has to be installed in the car. Cut a square box in the cover according to the size of USB port and a hole for led light. I applied carbon fibre vinyl sheet for refined look.
Step 3: Installation of circuit behind the coverThen I fixed the circuit board behind the cover using metal mender after which it gave this look.
Step 4: WiringThen I soldered the wires to the circuit board. These wires are to be connected to cigarette lighter for power. I also installed metal clips on the back of cover to fix it in the car.
Step 5: Final look before installation
Step 6: InstallationAfter that I fixed USB power socket into the console and here is the final out come.
that is super cool..great job
Great work and idea. Will replicate in my Pajero, but two for front and back. Hope I don't violate your patent:)
That is very nicely done! (Y) Should be very convenient now.
WAOOW... GREAT JOB..wanna ask few things . 1. it connects to power all the time (when ignition on) does the circuit of usb charger available in the market is strong enough to bear the heat. 2. did u connect a fuse to the device.
thanks
Thnx
Thnx sir u should definitely try this as this post is for rafah-e-aama
Thnx yes very convenient n looks good
Thnx. regarding your querries although i have used a very good quality charger but still cant keep it on all the time as it heats up so on/off switch needed which i have added but need to be fixed at some proper place which is not visible in the post and yes a fuse is also added.
Well done bro , i ll try to do this in my Cultus on weekend keep up the good work. Thanks
Nice work, Will replicate it
That's a year old thread. Ready made solutions are available now.
I jsut installed this, but yours is Sooper Cool!
You are right bro. But DIY is real fun.
Yes ready made solutions are available but DIY has its own charm.
Thanx. I also have installed this one in my alto
Absolutely
