THIS IS APPLICABLE TO ALL EFI CARS WHETHER THEY HAVE A DISTRIBUTOR ON NOT
I have a civic 99. It has an engine with a distributor and rotor, unlike new cars that have Coil over Plug ignition system ( Direct Ignition) without a distributor.
I wanted to install an Advancer/ Emulator in my car but the mechanics were not approving it. as they said that advancer cannot be installed in this car mainly due to presence of distributor.
So i decided to do it myself.
Here is some info about the Advancers & Emulators.
It fools the ECU of your car that the injectors are working and the car is running on petrol even when it is running on CNG.
It also saves your INJECTORS from damage as it turns OFF the injectors when car is running on CNG.
It Fools the ECU by manipulating the signals to ECU by various sensors. It intercepts the sensor signals & sends corrected/manipulated signals to the ECU so the ECU Advances the ignition timing as per the sensor signal automatically.
Basically it is installed so that ignition timing of the vehicle remains at default settings for PETROL as u drive on PETROL and automatically advances when you convert to CNG, without having to move the DISTRIBUTOR physically.
So the vehicle runs perfectly on PETROL as well as on CNG.
Normal Practice by Local Mechanics
I hav seen many EFI cars w/o advancer & emulator. (My car was 1 of them). Basically the mechs cut out the power wires of all injectors so the injectors wont run on CNG. So if u dont want to mess with the wiring, install an EMULTOR.
They generally dont install an ADVANCER & set the ignition timing as per CNG & say that u normally run ur car on CNG so it is OK. But what if we have to run the car on PETROL. It will have less power, jerks & missing and overall crappy engine when running on petrol, unless u retard the timing by moving distributor every time u convert to petrol & again when converting to CNG.
Note: A single loose wire on an EFI car can BURN your ECU costing u Rs 15000-20000.
Types of ADVANCERS/EMULATORS
1. EMULATOR ONLY
2. ADVANCER ONLY
3. A 2in1 ADVANCER/EMULATOR
Installing an EMULATOR only is no problem. It normally has a blu wire which is connected to the blue power wire of CNG Kit solenoid in the engine compartment. The black wire is grounded with body & the original holders of injectors are pulled off & plugged into the plugs of EMULATOR & Holders on emulator wire harness are plugged into the injectors. DONE ( A 5 Minutes JOB)
Installing a 2in1 ADVANCER/ EMULATOR
I have seen many different brands but most of them are local made with chinese chips. Dont worry even they have different varities. a good chinese 1 will do the job. As in my case i bought a TOMASETTO LOVATTO NEW CIP5 in Rs 1800.
You only have to get correct wiring harness along with it according to your cars brand.
The Only wires which you have to find out are the wires from your MAP/MAF sensor & TPS (throttle position sensor)
These wires can be found with the help of a voltmeter. You have to find out the wire that gives variable signal to ECU b/w 0-5 volts.
An easy way to find out the wires is to download the servive manual of ur car if u dont have it already by google. the manual will tell u the location of both sensors ant the wire u need to know.
Just cut the Signal wire of MAP/MAF sensor and connect with the device wiring as per the diagram below. then find wire of TPS but dont cut it, only peal it a little & connect the yellow wire as per digram.
Connect the BLUE wire to power 12v of CNG solenoid.
Ground the black wire to the body.
Connect the holders of fuel injectors as described above
& U R DONE.
Now if u have an oxygen sensor then connect it as per previous procedure. most old cars dont have oxygen sensor. Otherwise leave oxygen sensor wiring untouched.
Now switch ON the IGNITION. No lights will be there on the device. Now start the engine and switch over to CNG. The lights on the device should turn ON.
Description of LEDs
RED (right most) is the indicator for ADVANCE ACTIVATED. it should turn ON when u press the accelerator only.
GREEN (2nd on right) should be on when idling and not accelerating. the red light will be off at that time.
Forget abt the remaining three lights on the left if u have not connected the oxygen sensor.
FINE TUNING
1. Now its time for fine tuning ur system. Let the engine run till the time it reaches its normal operating temperature or the radiator fan turns ON.
2. Get your timing light if u have one & set the ignition timing on factory default by moving the distributor if required. THE TIMING MUST BE SET TO FACTORY DEFAULT & ENGINE RUNNING ON PETROL (NOT CNG)
3. If u dont have timing light then go to any mechanic & tell him to set the original timing on petrol. just a 5 minutes job. Should be free.
Now turn ur engine OFF & set the 4 switches on the device as under
1. ON (down) (OFF for standard advance on all speeds, ON for Dynamic advance as per the vehicle speed)
2. OFF (UP) (Only works if oxygen sensor connected)
3. ON (down) (Only works if oxygen sensor connected)
4. (UP) ( down for dynamic advance adjustment OFF and UP for dynamic advance adjustment ON)
5. Now Start ur engine & switch over to CNG. The lights should turn on.
6. At idling, only green light should be ON, when accelerating, only red light should be ON. If it is like that then u r done & enjoy the ride.
7. If the red light is always ON or turn ON after increasing lots of acceleration then adjust the advancer with the help of a turnable swith inside the RIGHT MOST HOLE beside the red light.
8. Let ur engine idle & insert a small screw driver into the hole & turn the screw fully right or left until the Green light turns ON. Then very slowly move it in reverse direction until RED light turns on. Now at this position move it slightly back so that the GREEN light is ON again but dont move any further.
9 Now the setup should be like this:
- Green light ON when idling on CNG
- RED light must turn oN when u start pressing the accelerator.
Everything is done & ready. ENjoy ur ride on PETROL as well as on CNG alike.
