the article shall cover disembly of front door panals of honda city 2005 or similar models, removing factory fitted speakers, and installing aftermarket upgrades.
this DIY was done on 26th of june 07, at Ghuncha@PW's place, speacial thx to him for his time and effort.
Guncha;s portable tool kit
step 1
remove lower half of hand rest by unclicking three clips at the bottom and pushin it upwards and slightly into the car.
remove the electic socket.
step 2;
open 3 screws inside the hand rest.
open 1 screw inside door handle
pull the door handle outside, its connected with couple of plastic clips aswell.
u will have to twist and pass thru the handle thru the door panel to remove the panal completly
step 3;
unplug all the plastic plugs on the main door panal, push it upwards, abv the door lock, and remove it.
Ghuncha makin sure all the plugs are out of there place
step 4
remove the FF speaker, use screw driver, press the top metal mount down, and exert some farward force, once unplug, pull the speaker up.
once removed, install the new speaker in its place, in most cases, it will be larger than FF speakers, hence u will have to make custom mount, this will vary from speaker to speaker, the hole in the door is not complete circle of square, our new speaker was having some difficulty settling down in one dimension, hence we had to modify the mount. i will let the pictures take over from here
Ghuncha doin some precise cutting
redbull_ar wiring stuff up
our after market speaker
Ghuncha;s Tools, that electric saw helped us alot
Cutting of one mount
me driling holes for screwing the speaker.
one of the speakers in place.
fixxing the door back.
sorry no picture after complete project, but beleive me the door looks just like it factory fitted
i will post clearer photos of the door tommo. enough for the time being
