Dear All,
This is my recent work regarding sound deadening of Charade 88, I have installed deadening sheet on the Firewal, Floor, and Trunk area, the car is having a better drive now.
First of All remove the dashboard and wiring connectors, there are four bolts near windscreen which needs to be opened and on the right and left there are two bolts on each side, once they are opened, then remove the steering wheel and indicator assembly, after it remove the Meter. Now the dashboard is ready to be removed, you can also remove gear lever console box if needed:
After removing the dashboard you can see the cooling box and AC unit:
Remove the cooling & heating unit by removing their nuts and bolts, once they are removed then I had installed the foam sheet of 3 MM, I had also applied auto sheet on the areas which were having rust (before the application of auto sheet, I had applied WD40.
Foam sheet is applied, now rubber foam sheet of 2MM will be applied on the foam sheet:
