Madhouse12: Sir another order coming up pre heat your solder iron
+1
diy! :d
i got some query where to buy audioquest from this thread. instead of replying seperately i might as well reply here.
I get my stuff from ebay which is not avalaible here. The process takes long time and is expensive and product lasts life long.and meanwhile i also try to use whatever avaliable in the country. i am a fan of high end audio systems and during past few decades i learnt 2nd best is just 2nd best. wires do play impt role in connecting high end,.
that corolla has 2zzge 6 speed now;)
Thank you for your reply Sir. So i guess i will have to import them
You are right Sir nice interconnects do help alot and 2nd best 2nd best
@ 2ZZ GE... WOOOW same engine that comes in Lotus Elise.. amazing Sir
picked up my set wooooooooooooooot XD
the first thing i felt
my daily driver settings, i put these rcas, n dang it smacked at the same settings
pre out voltage increased alot XD lol
@spl loved you DP
nd i luv urs
VG i used to like ur old dp better. that girl had sthg about her....
@splhave fun bro
aala...!
Co-axials rock!!
arslan abhi you didnt answer my question???i asked for the size of wire...
sorry for not replying earlier bro. well there are different qualities of wires available with different thickness. you can either use bigger size RCA connectors (size of the spring type thingy on the back) or you can get a thinner cable. RG-7 i was told can carry 7 amps current... not sure if thats true. i am using RG-6 and they are working just fine.
there should be an award for your DIYs,.. truelly fantastic.
keep up the "alternative" posts buddy.
thanks sir. more to come pretty soon
Increased quality but increased risk of Power wire distortion noise..These cables catch alot of magnetic waves nearby..Anyways, Nice idea
@F430
no sir its totally opposite. these do not catch any magnetic distortion as one wire is covered by the other and they are well shielded/insulated. same reason people use twisted pair cables.
plz sir dont b sory..thanks for the reply..shopkeeper will understand this "RG-6"??
Anxiously waiting for some more action from Dr. Madhouse12.....
yes he definitely will..in simple words..cable wali taar... RG-6 is the generic one used...just make sure to get a better quality one..mostly the softer and more flexible...the better...
like i use RG-11 for my home cable...was i DIY that i did (not chori ki cable replaced wire myself) ...extremely crystal clarity now
