guys lilttle bit of help needed,
i just successfully attached thimble to the windscreen which was broken in my city 2k, did it work only morning will answer this, the light on switch tuns on when it is tuned into on position, and herez what i wanna know driver side connector shows 10.87 DC volts when defogger switched tuned on and none when its off, means its good there, this one i connected just now, passenger side shows no voltage when grounded with body, but when both connectors are coupled to a volt meter it shows same 10.90 reading, which means passenger side is negative of the defogger?
