_______/\/\/\/_____|LED|________
|_______/\/\/\/_____|LED|_______|
|______|+ -!______________ ____ |
_/\/\/\/_ is the 1000 Ohm resistor that he has mentioned.
|LED| is the LED.
|+ -| is the battery. (+ is the positive terminal, - is the negative)
Also, keep one thing in mind. You will see two legs of an LED. One would be longer and the other would be smaller. Attach the positive terminal to the one that is longer.
Sorry, I could make only make this, using Opera on my mobile.
If you don't get it, google it! That would be the best! Or you can even watch some related videos on youtube if you don't know anything about electronics.
Sharo53
Good job! (Y) Chah gayay ho. Btw, gaari 30th March k liye to nahi teyaar kar rahay kahin?
