How Many Reps Should You Do To Build Muscle?
If youâve been working out for any length of time than no doubt youâve heard the debates over how many reps you should do per set in order to maximize your muscle growthâŚ
- Some people say âhigh reps for cuttingâ and âlow reps for bulkingâ.
Some say âgo heavy or go homeâ and recommend super heavy weights for low reps.
Others like to train a bit lighter and âpump it upâ and strive to keep the muscles under tension for longer periods of time.
But the question thatâs on your mind right now is:
âWhich rep range is the best one and which one should you use in your workouts?â
Well, there is no cut and dried answer to this, in fact you can literally make muscle gains training in all of the above rep ranges provided that you are putting enough demands on the muscle, training in a progressive fashion, and that your nutrition and recovery are adequate to support muscle growth.
But there are some general guidelines that you can follow to help you better structure your bodybuilding workouts and maximize your muscle growth. And thatâs what Iâm going to share with you here in this article.
Rather than randomly selecting some magic number as your rep range for all your workouts, you need to break things down and get more specific. There is really no such a thing as the one best rep range that works for all exercises. How many reps you do will vary greatly depending on the particular exercise you are doing.
For example, if you were doing deadlifts and then afterwards going to do abdominal crunches. Do you think that you would use the same set and rep pattern for both exercises? Of course NOT.
One is a heavy mass building power move, and the other is a small isolation exercise. They both work the muscles totally differently, so obviously you wouldnât train these 2 exercises the same way and use the same set and rep patterns.
Certain exercises are classified as Heavy Mass Building Power Moves and they work better for heavy weights and low reps. These are the âmeat and potatoesâ exercises that should lay the foundation to your muscle building workouts.
Than you have Mid-Range Power Moves that are still basic compound lifts, but these exercises are better worked with higher reps compared to the Heavy Mass Builders.
And finally you have Isolation Moves that are used for targeting specific areas of the muscles. These exercises work better with higher repetitions, lighter weights, and very strict form.
Generally with the heavy power moves your main focus is on moving the weight. With these exercises you should strive to increase the weights you lift on a regular basis (provided you can maintain good form of course). Than as you get into the mid-range and isolation moves your main focus should be on feeling the muscles working and getting a good pump. Rather than simply trying to increase the weights you are lifting.
Some examples of Heavy Power Moves are:
(Best Used With Heavy Weights & Low Reps)
Squats
Deadlifts
Barbell Bench Press
Barbell shoulder press
These are big basic free weight exercises that allow heavy weights to be lifted for low reps. The classic 5 sets of 5 reps routine works really well for these exercises. And advanced powerlifters and strongman competitors will even work up to heavier weights by doing heavy triples, doubles, and even single rep sets for these basic powerlifts.
Some examples of Mid-Range Power Moves are:
(Best Used With Moderate Weights & Moderate Reps)
Leg Press
Barbell Rows
Dumbbell Bench Press
Dumbbell Shoulder Press
Barbell Curls
Dips
Pull Ups
These are mid-range compound exercises that still allow for heavy weights to be lifted, but work better with moderate repetition range of 6-10 reps per set. These mid-range exercises will make up the majority of your muscle building workout program.
Some examples of Isolation Moves are:
(Best Used With Lighter Weights & Higher Reps)
Leg Extensions
Leg Curls
1 Arm Dumbbell Row
Dumbbell Flys
Side Lateral Raises
Concentration Curls
Tricep Kick Backs
Calve Raises
Abdominal Crunches
These are isolation exercises that work best when trained with light to moderate weights and high repetitions. Ideally you would use these exercises as finishing moves and do them at the end of your workouts. The idea here is to really pump up the muscles after youâve already completed your heavier power moves. Keep your reps for these exercises to 10-15 per set, and in some cases you can even perform higher reps (i.e. 20+ reps per set) especially with abs and calves.
ConclusionâŚ
These exercises and rep ranges are applicable to most weight training workout programs. However, there will always be exceptions to these rules depending on the particular training program. For example, the classic 20 rep squat routine is one such example of using a heavy mass building power move for high reps. And there will be other times when you may train isolation exercises with heavier weights and lower reps, especially if you are following a body part specialization program
However, the general training guidelines for most workout programs are:
- Heavy Powerlifting Exercises: 5 reps per set
- Mid-Range Compound Exercises: 6-10 reps per set
- Smaller Isolation Exercises: 10-15 reps per set
Now even if you have your weight training program structured perfectly with the correct sets and reps for each exercise, thatâs only one piece of the whole muscle building puzzle. What you feed your body is just as important (if not more important) than the actual workouts you do in the gym.
If you donât have your muscle building nutrition program nailed down pat, than you may end up like a lot of guys who waste their time and effort busting their butt in the gym only to look the same⌠day after day⌠month after monthâŚ
And the problem is â most guys have NO IDEA they are even making these errors and thatâs why theyâll never have a body that truly sets them apart from the pack.Good luck!
