Originally published at: https://www.pakwheels.com/blog/driving-re-defined-with-all-new-premium-fuel-xtron/
Attock Petroleum Limited has recently introduced a new premium fuel- XTRON. Having distinctive characteristics and amplified performance tendencies, XTRON is the next big shot in the generation of fuels. Explaining the features of the product, Attock Petroleum Limited has rightly put it in the words that says: “Experience the marvelous drive of your car with premium fuel, the Xtron.”
The all new premium fuel ensures better engine performance, protection against rust and corrosion and boosts its efficiency for you to drive your car the way it is meant to be.
And now you may ask, what are the benefits of this fuel. Don’t worry, we are here to tell you all about it. So, fasten your seatbelt and enjoy the ride.
Key Benefits
Let us explain you step by step:
- The biggest benefit of the new Xtron is that it gives better protection to your engine against rust and corrosion compared to its competitors. And the reason? the additive in it that acts as new corrosion inhibitor or in easy words, it keeps the rust away.
- Xtron keeps engine clean through its technology of clearing and preventing deposits, which settle in your car’s engine leading to lower emissions. In short, a clean air to breathe for you and everybody else.
- It will improve fuel economy of your car because Xtron is equipped with a friction modifier. This modifier helps in instant improvement in fuel economy. And presence of friction modifier will improve the mileage of your car.
- Xtron not only makes your future better & cleaner but also removes deposits created inside the car engine. XTron by Attock Petroleum Limited will help in restoring the lost engine power of your car.
- And finally, Xtron will enhance the overall performance of your car’s engine. This fuel keeps intake valves of your fuel injectors clean. It works by removing existing deposit and also prevents the formation of deposit at fuel injection system. And this enables a petrol vehicle to keep an ideal combustion originally engineered by OEM.
And these are few benefits-out of many we must say-for you and your car. The Xtron is the right choice of fuel you must opt for your car, because a healthy car means happy life.
