Can you share the rates for different thickness or at least the one that you purchased ?
i'll quote u the prices for 1 inch thick and 1/2 inch thich tmw !! but u would have to cleen cut the sheet urs self !!
Not a problem at all. Thanks for the help
its between 2 to 2.5k !! dnt rem exactly !! for 1/2 inch!! will tell u the eact outlet rates once i am confrimed !!
n yaa my half sheet wasnt used so i did one door with it !! so its cheep than Dynamat !!
Looking forward to the price.
1/2 inch thick 2500rs.. Its cheeper if u buy the whole role!! Its i guess (3X18). Go to Katys Tariq road. In the refrigation market n ask for the prices!!
Self adhesive?
can you give me the exact location of 'Katys' at Tariq Road. And where is the refrigeration market. Just tell me the exact place to look for there.
katys? where's that?
Have u seen jet audio.. Opposite to it in the lane!! Ask for katys from any one there. Backside of dolmen centre!! Flash kay pechay wala area..self addicive meants it is superglued on one side. Peal n apply!!
KATYS. it can help u people !!
seems like modern shop. will visit it tomorrow iA
Yup..But keep in mind yeah shop audio shop nahi.
1/2" is too thick i think. you will have trouble sticking it in different places.
I have 1 inch instralled:P up i knw.. 3/4 is enoughf as far as i think after u form the trunk too!! Its give cery cleen sound had tried that earlier n it was doing the job!!
That is exactly what I was wondering since dynamat is around 1.7mm thick. :s
can you post a picture of the material. Does it have a foam base because thats the only thing that comes to my mind which can be in 1" thick. How.much does the material weigh btw ?
Aeroflex USA, Inc. | Products | Aerocel EPDM Sheet for Duct and Large Surfaces | Insulation Tubes | Flexible Closed Cell | EPDM | EPDM closed cell foam | EPDM Foam | Rubber Insulation Products | Thermal Insulation Tubes, Thermal Insulation Sheets, Th
hope this helps u out!!
Do they sell aeroflex? Or the local variety?
Sent from my HTC Explorer A310e using Tapatalk 2
Is it something used for refrigeration equipments? If it adds considerable weight to a door, only then can sound deadening be achieved.
Can you show us some pics of ur car's trunk where its applied?
