I just changed the battery of my honda n wgn with Daewoo DL50. The original battery was almost dead. The eco idle is not working. What should I do? I read somewhere that reset ECU, while some said it would start working after a few days. While somewhere I read I might need to change battery? v confused
i guess, u need a bigger capacity battery to activate the eco idle function.
BTW, there shud be another battery under front seat , do also check the health of that
in honda n wgn there is none. only in suzuki
Kindly check if the battery has same specs as of previous one If the amperage of new battery are less then eco idle wont work
