HI,
i have an Alto 2017 Japanese variant currently i am facing a issue after removing lithium ion battery for interior cleaning.then ECO mode unable to work.A button just going to blink on speedometer.So please suggest how can it fix this issue.
Thanks
Did you plug it back correctly.
Remove the main battery terminal for 2-3 minutes and connect it again, it will reset the ECU and uske baad bhi na chala then maybe you damaged something while removing it.
try kiya tha...but didnt work.
there must be a flip switch over the battery casing locate that and try to reset. in all hybrid cars so far i have seen there is a circuit breaker switch.
I ham facing similar problem. I need to change my Lithium Ion battery but can't figure out where to get one from. Would someone be kind enough to guide me to where can i purchase used lithium batteries and how much is its price. I hace a 2016 Suzuki Alto 660cc. Older shape.Thanks
Bhai koe hal nikala tou btaden , facing the same issue
Same problem electrician told me just replace battery Get it from plaza Karachi
Same issue main ny bhe change krwae hy bettery but abhe tak same issue 5-7 bettery laga k dekhi hn same issue
