SZ viewer works perfectly with swift, today I got mine adapter connected with my swift.
Dear waiting for ur email because I failed to download it from apkmania.com as @nifiii brother suggested.
Uploading it on drop box and will share the link in your email shortly, BTW its v1.8.6 working great with Honda City 2016.
hoping it to work with my vitz with the protocol I stated in the above replies
I just send the link, just check your email inbox or spam folder, there will be an invitation from me for drop box file sharing.
I just shared a topic to identify the ELM 327 device (genuine or clone device).
OBD Driver connects like a charm on PKDM Wagon R but the free version only shows the bty voltage. Does someone has the paid apk?
Try SZ viewer, it works great with swift.
For which app?
He is asking for OBD Driver app.
Well I have checked Google and seems like no one has yet published pro version APK.
Better buy the pro apps and support the developers. Play Store apps are not so expensive. Just my 2 cents.
SZ Viewer APK file for manually installing it on Android head units with no internet access. Put it in USB flash drive and install it like you install apps on your PC. Just make sure you have enabled "unknown sources" setting from Settings.http://androidpicks.com/download-sz-viewer-latest-apk/
No harm in purchasing the app (OBD Drive) but before I do that just wanted to confirm if the paid version works completely, matlab it's displaying all data. Also, does OBD drive display DTC? Coz I didnt see any option of reading/clearing error codes in OBD Drive. Thnx
I am using free version and its displaying everything like rpm, engine load, short and long term fuel trim etc.
You just need to make sure that you have selected the right protocol as per instruction provided above.
I have read its description and there is no mention of dtc. It won't read fault codes or clear them. SZ Viewer can do that.
Obd driver is lacking to display and clear dtc code, for that you can use Scan master elm pc software.
Right. Actually SZ viewer is not easy to connect. Takes time and has to attach detach the tool several times, so was in favour of having the paid version of OBD drive if it could display the DTC.I think, i will manually select the protocol now as it is currently connecting is automatic mode.There are more than 1 options for Suzuki, which protocol to use for PKDM Wagon R?
Na yaar. Tried a few different protocols. It did connect but it only shows bty voltage and some data of x, y, z plane. Dont know what it is. Solution please?
That proved device is not that bad, you only need an app that will support the compatible protocols to read the ECU, you might need to google about custom initialization strings to be used with Torque app for the supported protocol.
SZViewer with ELM327 ver 2.1 is not working on Wagon R VXL 2017, any suggestions ???
