My Efi cultus 2009 need little push in morning than starts,if i switch it off after few minutes it may or may not start again,so its a risk to travel somewhere park it again try to start it and it tolds you to get someone for push so every time i pray that it starts. Sometimes its starts on itself also after a morning push and long time running. Battery voltage is fine. I am not that much good in car knowledge,need help and response.
does it have cng or only petrol. did you check the fuel pump pressure and fuses
first check the fuel and voltage supply.
Only petrol, cylinder removed,only kit installed
Battery is ok,can you tell how to check fuel and voltage supply?
Fuel pump and fpr. Distributor. Also battery voltage. If it drops too much ecu will not turn on and car will not start.Also check cng kit module.
you are experiencing typical issue of fuel pump wiring of efi cultus. please put this is search of Youtube 'cultus efi starting problem' and watch 1st and 7th video on the same issue
distributor ? EFI car has no distributorhe mentioned battery voltage is fine and no cng
so how to check fuel and voltage supply ?
So cultus doesn't has distributor hmm wah!!! When did that happened?Fuel pressure will tell you it has enough fuel supply on start or not. Suzuki has a habit of dropping voltages at ignition switch. So have to check how much are reaching to ecu.
sorry my mistake ,.. i always thought efi cars have independent plug coils .. just googled cultus engine and it has a distributor
Yes sir g10 came with distributor.Baleno late models doesn't have distributor.
Issue solved,sulf needed cleaning,i got it opened,serviced and fixed,now no starting problem,thanks fod response fellows
