i have Mehran 99 model.engine oil low ho jata hy. aur jis waqt bhi car start kro. boht zyada dhuwa nikalta hy. phir band ho jata hy. engine ka noise bhi boht hy.kia wja ho skti hy aur theek krwany ki kitni cost ho gi.??
Idea nh i have also put a question
rebuildi g cost for mehran is low first u need to check if your card has an head issue or u need a complete overhauldoes it only smoke on startups or all the time and what is the color of smoke
color of smoke os white. it becomes on start and some times during drive.
check for oil droplets in radiator looks like a weak head gasket to me
Righti check it.
How much it costs to overhaul.??
bro it will depend upon the problem 1st u have to learn whats the problem is then u can have an estimate
how much it costs for complete engine overhaul. A to Z
30-35k with japanese parts. If done properly can last long time.
You need to over haul your car engine. These are signs if a weak engine. U have to put new rings in ir. It will cost you 8 to 12k. Talk to an expert mechanic. Its 99 model.
thori c bhi drive krny se bhi gari boht gram ho jati hy. But band nhi hoti. Engine se boht heat nikilti hy.
Radiator is also leak. You should over haul your car engine.
engine ka garam hona "zaroori" hai had se ziada garam hona engine k liye khatarnak hai temperature ka kanta kaha per hota hai?
temperature ki gauge cool per hi rehti hy.
its a weak head gasket go to a good mechanic to check the condition
