Do you guys know what spec or size alternator belt should be used here? 2000 Daihatsu Mira Gino L700s 660cc
Count the grooves in the pulley, those are the “pk” number, use an inchtape and measure the belt run, thats size in millimeters
ok thanks. i have one pair that has 3PK and then the other has 4PK, now i just have to try and measure it to get the length in MM , hopefully i can fit the measuring tape inside it properly.
You need to drape the tape exactly as the belt routes on the engine taughtly, and add 10mm or so give or take, to get a good size.
Btw
Does your engine have 2 separate belts?
it seems like it has the 3PK belt which i think is 3PK525 , a 4PK belt and a belt that says 9.5X675La, not sure what that one does but im replacing it too.
