Iam having corolla XLI 2016 model and I need to clean the engine through hydrogen carbon cleaning process which requires 30 - 50 mins and asks for 4000 pkr should I go for it are these guys trusted will this process restore my engines life and increase its performance?
It will just improve the engine life.
Bro if there is some genuine need for it, and your vehicle is giving problems relating to Catalytic Converter, etc., Only then go for it. Otherwise, no need for any such chaaeer chaar.
Don't fix what is not broken. There is nothing of the sort mentioned in the owner's manual, which to me means that there is no need to get it done. Unless of course, the car has been in some special circumstances, and has had some special damage to engine or catalytic converter.
Its a chay bananay ka business, this hydrogen cleaning manjann.
Just drive your car normally, use correct oil and fuel spec in it and make sure thermostat is in place.
The cat self cleans itself.
What do you mean by thermostatr in it? Actually I also want to Clean CAT and carbon cleaning.
Means dnt run ur car without thermostat, most people remove it due to which engine never achieve operating temperature.
That's not true. I have used the correct recommended oil in my car. Plus cooling system was in optimum condition aswell. But my CAT con was v dirty at 65k. So please elaborate how its self cleanable?
sir what is the scale of dirty, very dirty & clogged in case of CAT Converter? did ustad surgically opened and now telling you that ??
for desi cat cleaning check you tube videos.
before that i suggest get your vehicle scanned and decode the error codes using google. @altisdualvvti
I would suggest a nice italian tune up.
Doesn't helps much. I drive quite aggressively and still it almost choked
What engine oil are you using? Is thermostat present in engine?
0W-20 which is recommended for my car. It's not a Corolla by the way. Secondly yes thermostate is present as I said before cooling system is in perfect state.
I don't know much about how catcon gets clogged, but fuel quality is so pathetic that I get fuel filter of my corolla cleaned after every 40k kms. The tray was full of dirt everytime I got that cleaned up. For catcon cleaning I use proficar cat con cleaner at every 10k kms and keep rpm at 3-4k for 30minutes on motorway. It makes humongous difference in engine response. Catcon is still healthy after 100k kms, but that is due to additive. If I don't use additive I feel severe lag in acceleration and fuel economy issues after 20k kms. Putting pedal to the metal throttle gets so dirty at 40-50k kms. I use original air filter which I change after regular intervals.2016 Corolla Altis 1.8 cvti. Engine oil is amsoil signature series 5w30 100% synthetic.
How is fuel filter cleaned? Its meant to be replaced.
Pour in some fuel in it, shake it up and blow air through it. Voila, all the gunk will come out. Takes 2L of petrol to clean it completely. It will be good for next 40k kms. Toyota dealerships does the same but they hit it with a spanner to get the gunk out, which I don't like.
