I've recently bought a Swift 2007 Japanese Automatic Transmission, and have noticed that Engine malfunction light comes on occasionally after having the tuning done, Even though the extra noise of engine has gone but the ignition self is taking an effort to start
Plz help, Thanks
only after tuning?how does it turn off?
what do u get done in tuning ?
After a restart few hours later it wasn't thereAnd can I ask how can I make a copy of the immobiliser key with a chip for cheap in Isl. / PindiThanks for ur reply
In tuning just the plugs Cleaning and he checked the throttle if it's clean or not and Break pads cleaning
it should start on half selfshow the car to a better different mechanic
if the car was giving a malfunction code, light would not turn off at all
try mokeys(Muqeem bhai) opposite jehangir balti in saddar
Thanks, I'll get that checked
From Kamran market. They use some scanner tool to get the code from your car and then make the key. Not sure about price but I asked once the key-maker about it in Kamran market. He said its possible.
The MOST common reason for the check engine light to turn on is malfunctioning O2 sensor. Either get it replaced (if you want to spend money on it ) or just get the battery terminal wire detached for a minute and then attach again. CPU will restart and check engine light will vanish.
