I have honda city 1.5 aspire PT 2018 when I change the gear from D to R or P to D engine moves forward or backward little bit is it normal?
Don't press the brake very lightly like it's a formality. Press it how it should be pressed.
I press the brake tightly but same result
Brother I mention engines move not car
How do u know the engine moves?..what to do u feel listen or see??
Slight movement is normal in all cars due to flexibility in engine mounts
Why are you staring at the engine with the hood open and looking for movement? It’s an engine sitting on rubber mounts ofcourse it’ll move when you put it in drive because you’re loading the torque converter.
I see with my own eyes
