The word "Gonj" basically used when car gears generate noise. and if your car noise is due to gears its quite common in old cars or in cars which are used roughly and gear oil level is low.. and gear noise can not be eliminated; only option is to replace gear box... so check with some good mechanic and it will identify the origin of sound.
Its not dangerous just keep checking gear oil.
