Hi friends now you can buy the best oil name as XADO it is Atomic oil, This new Tecnology introduced by Ukrainen company it is avilable in EU, USA and other countries. It is with revitalization
(The term "Revitalization" (from Latin "vita"=life) literally means "returning to life". The revitalization process is based on unique physicochemical processes which, under certain conditions, take place in the friction zone.
As soon as a mechanism begins to operate, it starts to wear out. Eventually, something will fail. Under load, the working surfaces of the parts rub, overheat and deform. Metal particles are simply taken away and wiped off the surface. Having lost weight and shape, the part cannot serve properly and fails.
XADO contains a building material and a unique energy activator which uses excess friction energy to create a new surface. It turns out that overloads, i.e. excessive energy which can ruin the inter-atomic bonds and damage the parts' surfaces can be "withdrawn" and even more - can be used for the growth of other matter! )
