Sam,
100ml, is about 0.3% of oil mixed in 30 litre tank, that should not cause a problem, but if you ask me personally, i'd rather pull the fuel lines and check the diesel for viscosity.
Proverbial Slang,
The fuel filter was brand new, injectors cleaned and the pump recalibrated. The reason was the diesel became viscose and cause the pump to handle more pressure, and the viscose deisel did not go through the nozzles, but as i said it was only me. The fuel filter had oil sitting at the bottom.
