if oil filler cap is off and oil keeps squatting out while the engine is running .. what does it Mean??? Is it a sign of worn out engine...?? The engine is 2Lt
not at all.
remove oil cap in a brand new car and hold a clean paper 4 inches above the filler hole it will be squirting oil at throttle
Is it not a sign of back compression?
depend on car maintenance history.
in back compression there will be plenty of BLOW with oil sparkles only
At idle rpm every engine has a amount of blow. Rev the car to 2000rpm then check blowby.
i understand if the engine is blown up then it blows out air plus smoke.... in this case there was neither blow.. nor smoke.. and on throttle was feeling my palm sucked in a little.... it was 2l turbo..
suck in means the valve seals need replacement.
