U can try putting 5w30 and if it doesn't get reduced or give any problems then you can use that.
how about 5w20? is it good Zic 5w20?
i was basically going for 0w20 or 5w30, because of my mistake i asked for 5w20 (i don't know why i did that i knew it was 5w30) now running it on 5w20...
Its even better.
Okay Thanks, let see if it gives better performance
What about if the engine is blowing (engine blow mar gya he). What grade should be used?
2 posts were merged into an existing topic: Lubricant Discussion- Engine Oil
