ENGINE LUBRICATION
Oil capacity (drain and refill), L (qt., Imp.
qt.):
4A-FE engine
With filter 3.0 (3.2, 2.6)
Without filter 2.8 (3.0, 2.5)
7A-FE engine
With filter 3.7 (3.9, 3.3)
Without filter 3.5 (3.7, 3.1)
Oil grade:
API SH, ?Energy-Conserving II? multigrade engine oil or ILSAC multigrade
engine oil is recommended.
Recommended oil viscosity (SAE):
For Pakistan 10w30 is recommeded unless you live in colder areas where temperature drops below zero. 5w30 will improve your startibility at cold temperatures. Also your engine might burn oil and it isn't something to worry about unless it burns like all of the oil in 1000 to 3000kms, by the time my 4afe travels 4000km oil is decreased by quarter but it isn't bad unless it drops below half.
MANUAL TRANSAXLE
Oil capacity, L (qt., Imp. qt.):
1.9 (2.0, 1.7)
Oil type:
Multipurpose gear oil API GL-4 or GL-5
Recommended oil viscosity:
SAE 75W-90
AUTOMATIC TRANSAXLE
(4-speed type)
Fluid capacity (drain and refill), L (qt., Imp.
qt.):
Up to 3.1 (3.3, 2.7)
Fluid type:
Automatic transmission fluid DII or
DEXRONIII (DEXRONII)
AUTOMATIC TRANSMISSON
(3-speed type)
qt.):
Up to 2.5 (2.6, 2.2)
Fluid type:
Automatic transmission fluid D II or
Spark plug type:
NIPPONDENSO K16R-U
NGK BKR5EYA
Spark plug gap, mm (in.):
0.8 (0.031)
