I swapped GA15DE from GA14, 3 months later,and i used only 120 km’s on that Kabli Assembly.I used 20-50 havoline on the first startNow which engine oil will be good for it?Also it’s fuel consumption is high what to do
@dani_kkcan be of help
Best oil grade for ga is 10w30 /5w30 /5w40 /10w40.However i would suggest you to stick with any 10w30 grade oil. And monitor if it's getting consumed or, you feel any smoke... If all good your ga is going to get little bit fuel efficient. And ga has 11-13kmpl local economy so there might be some wiring blunder.
Use Caltex Havoline Formula 10W30 engine oil. Check o2 sensor if its present or not?
Ok dear,i will put havoline 10w-30w in it,and then will check and also tell you, ohh that’s a good fuel average in locals,I will check through Scanner what’s the fault...... thankyou so much
Okay sir,i will use 10-30w havoline,will check by electrician Thanks alot
Thanks
