Dear Experts,
I have recently purchased Toyota Corolla Altis Grande 2017 model. 88,000 KMs driven already. I need to change the engine oil but not sure about what type of oil and brand should I go with.
Can you guys suggest me on that?
Thanks
Shell HX7 5W30Total Quartz 5W30Caltex 10W30Toyota Petron Plus 10W30Toyota Japanese Oil 5W30 tinpackIt takes 4L.
Is this the picture from Toyota Corolla Altis Grande 2017's owners / users manual?
@basitali87. The manual i have is in pdf form. Not sure if its for 2017 .
Which engine oil grade / viscosity, and brand is currently in use?
That's why I hadn't replied, as to me, it does not seem from the owners / users manual of PKDM Toyota Corolla Altis Grande 2017.
IMO, it will min. start from 5w-30 there.
Doesn't it take 4.25 litres???
PKDM Corolla Grande is equipped with a 2ZR-FE engine. It takes approx 4.2 liters of engine oil when filter is also changed. In Pakistan you can use 5W-30 grade engine oil year round without any issues, the image you shared is from Generic manual of Toyota. an aged (80000 kms or more ) 2ZR-FE is also notorious to consume 1 litre engine oil every 1500 kms.
It does but 4L is good as well.
I have poured 4.5 litre engine oil in grande 2015 model koi issue to nh hoga issue ?
never poure more than the recommended oil quantity otherwise it will leak the oil seal, check by dip stick if it's much more than the upper line then remove the extra
