both oils are fine and are good.
since these are high end synthetics so expected to reduce over time quicker, do keep a check on oil level and keep it topped up. as i said depending upon your traffic conditions and driving style you can opt for any of the two.
if it was me i would go for 5w-50. more protection the better.
also if an oil takes longer to let engine reach the optimum operating temperature (in the morning-usually happens when you have recently changed oil), it means that the oil is good and lubricating your engine inners well and working properly that is why engine is warming up with a delay which is actually a good sign of an oil.
cheers.
