Recommended car (Aqua) SAE is 0w-16, now if I have used a higher grade (5w-30) for 1-2 years, going back to the recommended grade or 0w-20 will cause any problem? Should I keep using 5w-30 or change to 0w-20 or 0w-30?
2nd question is I'm using 20w-50 in Hijet turbo 660cc engine, people on the PakWheels page told me that 660cc isn't built for this type of oil and I should go back to 5w-30, etc
my question is, recommended oil grade is of japan, so can we use that recommendation in Karachi as well? or the climate changes that according to the area?
I need suggestions on this matter. thanks
