0w20 is the ideal oil.
But you can also use 5w30. 10w30 is a bit thicker but not too thick. It will also work ok. Make sure it is fully synthetic.
These oils are used throughout the year, all seasons, hot or cold. Never put 20w50 in any modern toyota engine made after 2000 where fully synthetic is used.
Change oil after 6000km if it is fully synthetic. 3000km is too early.
Little oil reduction is fine.
