Aoa,
Honda City 2015
86600 KM (5W30 oil)
1st Owner
I noticed a problem of oil seepage on the backside of the engine. Oil not dripping on ground and there is no drop in oil level. Just seepage.
Kindly guide about the reason and solution.
- One guy said that it's coming from the loose silicon of the timing cap. He said that the timing cap will be removed and silicon reapplied to solve this.
- Another guy said that, it's just coming from the crank case. He said to just tighten nuts and bolts at the bottom and it will be over.
- A close friend of mine said to continue driving the car in same condition till the time oil level drops or oil drips on ground. He said that its pretty normal. (Don't like this idea much)
Kindly experts Bhai guide kar dain.
- What is the possible reason for this. (car is well maintained and all oil changes are from honda) (driven daily for 02 short trips of 2-3 KMs for kids drop off at school)
- How bad is it
- Solution for this
- Recommend a place in RWP / Islamabad for this issue.
I will be grateful for your kind help.
