Can we use NOS Octane booster for high performance and Engine OilTreatment Solution for Cleaning Engine and kindly give advice Which one can we use and how can use.
Octane boosters usually contain manganese which gets deposited on spark plugs nd clogs catalytic converter, even the so called hi octane petrol here gas high levels of manganase. Better to stay away from such products. I drove a civic 260,000kms and never had the need of even changing fuel filter. Just get ur fuel from a gud pump, which is....A good brand engine oil of proper recommended viscosity, no need of engine treatments.
Brother always use recommended engine oil grade / viscosity from some reputed brand, and change oil + oil filter after regular intervals. I hope, by following it, engine will remain clean. IN SHA ALLAH.
Second is the fuel; use fuel from well-renowned and preferably, company operated and maintained fuel stations, and you are good to go. IN SHA ALLAH.
Shell, Total, even PSO are good brands.
I won't suggest high Octane, HOBC, etc, for your Cultus.
Just use regular fuel, and everything would be fine.
Not recommended in any case for your ride.
Only if you are having problems with your engine, engine oil, etc.
Fellow member has rightly guided you about their use.
I hope, it all helps. Thank you.
If you don’t have any problem, don’t try gimmicks. Only Shell HOBC is manganese free. But HOBC is not for low end cars.
