Salam
My office colleague has a 2011 mehru, which is releasing white smoke and reducing too much oil. Smoke is not thick but oil is reducing alot.
There is a leak in the engine-gearbox seal as well.
Quick knowledge and understanding says engine need Rings replacement only, right?. But our office mechanic says to get it properly overhauled in one go, and says to replace all, piston, rings, bearings etc making an estimate of 40k about.
I had a 91' mehru, and our old mechanic did a ring replacement work only, at 155k km. Which was done good and car ran a further 30k kms without any oil loss or smoke and 13 fuel avg. 30k km ke baad actually heat up hogai due water pump failure only.
So as per my experience only rings replacement should be done.
So is it possible that engine is opened and only the rings are replaced. What other parts may need replacement as per its condition?
