@vicky_boy!
Okay, what you have stated, is not called "Complate" engine Overhaul. Its just Head, Cylinder, Piston and Piston Rings replacement. But yes, you will have to change everything including:
- Piston & Piston Rings
- New Gaskets for everything
- Valves & Valve Seals
- Push Rods
etc
If its the first time your bike is getting opened, then:
- Stock sized piston will work
- No bore will be required (You will have to ask them specifically NOT to bore it, unless absolutely necessary)
- you don't need to change the Cylinder Block, Valve Springs or Rocker etc.
This is coming from my experience while getting Piston Rings change on my CG125. I opted not to change the Piston, thinking its fine and it'll work. Result, it needs work once again because the oil is still leaking in Combustion Compartment.
Also, its not really complete info, but others might also add to it, clarifying it more.
8k is a little high for such a work, but i think this is including the Cylinder Block change, and other petty stuff. I got my work done, somewhere in 5k (If i am not mistaken). Labor was roughtly 700-800 (can't remember exactly). Also, I didn't change the piston so thats another reason why my costs were lower.
There are better (Japanese) parts available so find them first. Otherwise, AHL's genuine wil do.
