Hi,
Recently V belt (Vitz 2008 2SZ) was replaced due to previous one worn out completely. Now I am hearing increase engine sound, only while you pull the car or you can say when load is applied on the engine. Sound is like gurrana (to describe in the best possible way).
Mechanic has already check the tension, its neither lose nor too tight. He said it will get normal with the usage as the belt sets in.
Is there anything more which I should look at, like the tensioner.
Regards,
Abdul
