Disconnected the CNG today. That stupid A$$h0le CNG installer had cut all four wires (probably the ones connecting to the injectors, all four carry the same color, Red/Black).
After much effort, I managed to connect three of them (by means of jumper wires, as there was no play in them while passing through pipes). The engine started on petrol without pressing the accelerator.
The wires have been taped, but the connections are not perfect due to extremely limited space. Extreme caution was required to cut to remove the insulation.
Will try to run on very low RPM tomorrow, then see how to put the wires from end to end without any joint in between.
And it will also require the removal of venturi stuff and somehow undo the damage to that MAF pipe.
