I was expecting this question from you after reading your thread about fuel pump. And to your disappointment, I never supervised it
Those are I think a team of 12-15 guys, 4-5 electricians. It was load shedding after Maghrib, and wiring work was being done by hooking up a bulb with battery. Then I noticed that 2 guys were working on the fuel tank simultaneously. It didn't take much time to finish off the wiring as well as fuel pump installation.
To be fair, if someone wants to cheat you, he will cheat you in any case. So I always leave most things to the honesty of others (Had it not been so, the swap won't even be needed at all, if I had monitored each and everything related to overhaul!!!).
