I am getting light on in my mira 2012-15 model from couple of days,
https://ibb.co/YtvFqnc
when i start car it shows for few minutes and then go off and never see no matter how login i drive.
What can be wrong?
Check the coolant level.
You mean water level in radiater? its full?
if by coolant level you mean something else pleases mention
Yes inside the radiator. Check the reservoir bottle first. Between is there's coolant inside the radiator or water?
OK, Thanks let me check in shah ALLAH once reach home
bhai jan ghar nai pohnchay abhi taak ??
hope you & vehicle both are ok.
Can I add more water on check engine sign if I've mixed coolant and water in the first place?
If your are is showing check light it means there's some error saved inside the ecu.Use an obd2 tool to check the error code and sort it out.Why are you adding water if your car got coolant already?
