Hi Guys,
Sometimes when I am driving and press the clutch with idle accelerator the engine quickly shuts down. This does not happen always though, but I have tried many times when I am going in normal speed like 40 - 60KM/H and press the clutch with idle accelerator the engine shuts down.
Then also sometimes, when I start the engine and press the clutch, the engine shuts down even before putting in first gear.
When sometimes downshifting pressing the clutch engine shuts down again and wont start easily when I keep pressing the clutch in gear, I have to release the clutch and put the gear in neutral and then engine starts.
But it does not happens always, just sometimes and its very annoying me.
I read online that it can be ECU issue, and just pull out the battery for 1 minute and then it will reset the ECU and put the battery in.
(Edit:29MAR18: Tried ECU reset, does not resolve the issue)
I took the car to a mechanic and he did a test drive although this didn't happened with him and he said everything is ok But I am sure something is not ok as it wasn't the case and because it does not happens always it may be mechanic wasn't able to check.
Did it happen to anyone else?
