The 10E error on your Daihatsu Move's meter is likely related to the vehicle's transmission system. In Daihatsu vehicles, the "E" typically stands for "Engine," and the error code "10E" could indicate an issue with the engine or transmission.
There are several possible reasons for the 10E error to appear on your Daihatsu Move's meter. Some potential causes include:
Transmission sensor malfunction: This could be related to a faulty sensor in the transmission system that is not providing accurate readings, leading to the error code.
Transmission fluid issue: Low or contaminated transmission fluid can cause issues with the transmission system, resulting in error codes like 10E. Checking the transmission fluid level and condition could be a good starting point.
Wiring or connector problem: There could be an issue with the wiring or connectors that connect the transmission system to the vehicle's computer, resulting in an error code.
Transmission control module (TCM) malfunction: The TCM is responsible for controlling the transmission system, and a malfunction in the TCM could trigger an error code like 10E.
Mechanical issue: It's also possible that there could be a mechanical problem with the transmission system, such as a worn-out clutch, a damaged solenoid, or a faulty valve body.
To diagnose and resolve the issue, it's recommended to take your Daihatsu Move to a qualified mechanic or a Daihatsu dealership for a thorough inspection and diagnosis. They will be able to use specialized diagnostic equipment to pinpoint the exact cause of the error code and provide appropriate repairs or replacements as needed. Avoid driving the vehicle for an extended period with the error code, as it may cause further damage to the transmission system.
