Keep It cool. Flamers will get INSTANT BAN
iMod]
News Source: Tata Nano will come in a total of three variants: Base, mid level CX and top end LX The car meets all the safety criteria as per Indian standards and will be able to seat 4 people comfortably. Engine Technical Specifications: Rear Mounted All Aluminium MPFI EMS(Electronic Engine Management System): 32 Bit Microprocessor with “blink code mechanism” for easy repairs Displacement: 624CC, Petrol with Single Balancer Shaft Drivetrain: Rear mounted engine, rear wheel drive No. of Cylinders: In-line 2 Cylinders Valve Gear: 2 Valves per cylinder, 4 valves in Total Maximum Power: 35 bhp @ 5500 rpm Maximum Torque: 4.8 kgm @ 3000 rpm Compression Ratio: 9.7:1 Power to weight ratio: 58.3 bhp/tonne Safety: Standard Tubeless Tyres Fuel cut-off in case of collision. Fuel Cut-off @ 5600 rpm in any gear or @ 105 kph Performance: 0-60 kph - 8 Seconds (Est.) Top Speed: 105 (Limited) Transmission: Gearbox: Cable Operated, 4 Forward Gears, 1 Reverse, All forward gears synchronised Gear Ratios: 1st: 3.45 (Recommended Shift @ upto 10 kmph) 2nd: 1.95 (Recommended Shift between 20-30 kmph) 3rd: 1.26 (Recommended Shift between 30-50 kmph) 4th: 0.838 (Recommended Shift between 50-70 kmph) Reverse: 3.08 Suspension Front: Independent McPherson Struts shock absorbers Rear: Semi Trailing Arm. coil spring with gas filled shock absorbers Brakes Front: 180mm Drums Rear: 180 mm Drums Wheels and Tyres Wheel Size: 12″ inch Front Tyre Size: 135/70 R12 Tubeless Rear Tyre Size: 155/65 T12 Tubeless Spare Tyre Size: 135/70 R12 Recommended Tyre Pressure: 26 PSi (Front), 28 PSi (Rear) Dimensions and Weight Length: 3099 mm Width: 1495 mm Height: 1620 mm Wheelbase: 2230 mm Ground Clearance: 180 mm Kerb Weight: 600 Kg Fuel Tank Capacity: 15 Litres Fuel Consumption: 23.6 Kmpl (Est.) Battery: Semi Sealed placed under the Driver Seat Boot Capacity: 80 Litres, 500 Litres (with rear seats folded) Features: Nano Base: Seat Belts: ELR Front, Static Rear Engine opening through rear bumper Speedometer and Odometer High mounted Rear Stop lamp Centrally placed exhaust Only Driver seat adjust-sliding and reclining Fixed front passenger seat Folding Rear Seats 2-Spoke Steering wheel Grey bumpers and interiors Driver side Outside rear view mirror Tata Nano CX (Along with the features of Base Nano Adds the following) HVAC (Air conditioner with heater) Tinted Glasses Driver and Co-driver seats with slide and recline adjust 2 tone grey interiors and seats Optional Metallic paint. Tata Nano LX (Along with the features of Base CX Adds the following) Tripmeter Front Power windows Central Locking Front and Rear fog lamps 3-Spoke Steering wheel Moulded door trim with fabric inserts Floor console with glass holder Anti-Glare inside rear view mirror Sunvisors on both sides Warranty 18 Months or 24,000 kms whichever is earlier Service Intervals Ist Free Service: 1000 kms or 1 month whichever is earlier 2nd Free Service: 5000 kms or 6 month whichever is earlier 3rd Free Service: 10000 kms or 12 months whichever is earlier Every subsequent service after 10,000 kms Color Choices Nano Base: Bright Red, Ivory White, Summer Blue Nano CX: Bright Red, Ivory White, Summer Blue, Champagne Gold, Lunar Silver Nano LX: Champagne Gold, Lunar Silver, Sunshine Silver Booking Date: 2nd Week of April, Forms will be available 7 Days before the booking date is announced, available only for 14 Days. Forms Availability: State Bank Of India (Selected Branches), Westside and Croma Stores, 400 Tata Dealers all over the country Cost of forms: Rs 200-300 (One form per customer) Booking Amount: 70% of the price Allotment: Random number lottery Pics of the Nano being delivered at a showroom: Watch how easily it can accomodate 5 adults.
