During recent rains experienced water making its way inside door panel & not inside the car- had removed the water as there was a drain plug provided. Is this something that is expected when you drive the car through large water bodies or there is a leakage in window seal causing the water to accumulate during rain. Thanks
same is the case with Revo as well, take it to a wash or through deep enough water puddle and then you can hear water splashing. Remove the drain plus and let it drain off. some stupid design issue or PKDM gift dont know
Hopefully the mechanism inside the door panel has good rust prevention coating to avoid future creaking sounds Thanks!
