Asalam O Alaykum,
I need help to improve my car performance and assembly sound issue.
My vehicle model is 2010 Suzuki Alto VXR 1000cc average was 10.25 KM to 11 KM per liter in city and on motorway it was 15 KM. CNG cylinder was removed almost ten years ago also most of that time period it was used on petrol.I used full tank of Hi-Octane fuel to improve car average performance plus a thought was that it will clear my vehicle engine which will make my car engine clear.First Issue:Now I am here to have an expert view as its average downgraded to 7.6 KM and current average is below 5 KM.Second Issue:My vehicle even after ignition remained soundless and now noise like a small drum from left side seems like assembly sound.
Also guide when timing belt can be changed as I purchased when it was zero meter and now near 94000KM on same timing belt.
Guide which plugs and wires will be best as if required however oil change process was on or before time and tuning was also done regularly and rest checkups were also done which were mandatory part for a vehicle.
Please guide.
Walikum Assalam.Get carburetor checked.Spark plugs,air filter,keep fan auto for fuel average.For sound issue check engine and gear mounts as broken mounts can cause vibration.For timing belt u need to see owners manual.I,d say at this age change it now as it's very important part.No idea about spark plugs.Btw by assembly u mean engine?
First of all thank you for the response.Nothing is damaged or broken.Assembly no accurate idea some people also used as foundation however sound is from engine near above front left tire but from engine side.
Is sound on idle or when car is moving
timing belt are normally changed at 100,000 km.
your timing belt change is due.
if you get original timing belt, it will last another 100,000 km, but original is very unlikely now.
so change next timing belt at 80,000 km.
which engine oil grade and brand ur using is fan still auto or direct and what ur using in rsdiator coolant or water?
Mostly while idle and rarely while on move.
Thank you for the response, any idea from where a new original one can be baught and what will be the approximate price tag. Also guide the remaining. Regards
Thanks, Havoline Formula 10w30 3 liter since day one.Fan is on auto.Regards
thats gud how is the rpm of ur vehicle is it high?
My vehicle model is PAK assembled which comes without RPM meter.
i mean do u feel abnormal rpms during idling like rpm is high ive got mine 2002 alto fuel consumption issue solved by bringing it down to 900 rpm
Respected Brother, Didn't sound any difference however cannot say regarding RPM as don't have RPM meter. Thank You.
Mine looks like this
check for punctured vacuum tube abrupt idling is a phenomena when vacuum advance is not working.
Okay, will you please go through my whole requested details given in start so if any other guidance you may give me in this regard.Thank You.
cannot exactly say....
Gates, BANDO, Michelin etc make all sorts of belts.
in karachi, there are several dealers near plaza market.
what you should do is get fresh stock. which must have been kept in the dark, not hanging in sunlight.
Thank you are these brands for timing belt ?
these are brands that make all sorts of belts, including timing belts.
