Guys I need your opinion on this 4 channel amp Soundstream TRA 960.4
I am getting this amp in used condition for from a guy in Islamabad. Its ratings etc on the net are quite good but I want to get first hand info from experts here. I would be driving Alpine Type R front components and a JBP P1222/Alpine Type R 12" on it. Would this amp be able to handle both of these? And is the price ok?
Most importantly, how can I thoroughly check the amp? because I would be going all the way to Islamabad to purchase this and therefore would want to ensure that it is problem free and not repaired.
Looking forward to your replies!
The specs of the amp are
4-Channel Amplifier
120 watts x 4 chan. @ 4 Ohms RMS
240 watts x 4 chan. @ 2 Ohms RMS
Bridged: 480 watts x 2 chan. @ 4 Ohms
THD: < 0.02%
Frequency Response: 10 Hz - 50 kHz
S/N Ratio: >115dB
Damping Factor: >500
Input Sensitivity: 0.15 - 12.0V
Crossover Slope: 12dB
Crossover Frequency: 50 Hz - 5 kHz
Dimensions(in): 10.75x2.6x21.5
Variable high pass, band pass, low pass
Variable 18dB bass boost
Double sided glass epoxy SMT circuit board
PWM mosfet power supply
Tri-guard amplifier protection
SMT cooling fan built in
Tri-mode capable
Line output
Soundstream TRA960.4 (tra9604) - 4 Channel Amplifier | Four Channel Amp - Sonic Electronix
