Dear PW Member,
I am facing problem while shifting of gears as it works sometimes so smoothly & sometimes it gets too hard while shifting & make grinding noise.
Consulted with 3 mechanics two of them says replace clutch cylinder (master & slave both) however no leakage found in any of the cylinder & 3rd one says cylinders are working fine clutch plates, pressure plates needs to be changed (car pick & clutch position is fine).
Gear oil changed with Honda MTF and drove 10,000km only.
Please suggest a reliable solution & mechanic in Lahore.
Thanks.
