... so I literally ripped off the dashboard to check the wiring and boy it was MESSY.
I have corrected all the wiring, some of them needed replacing (Now i know how ******* hard it is to find heat shrinks/sleeves in lahore.).
replaced the duo valve, the old was bad, the solenoids were not even clicking when literally hammered.
the EVAP sensor is MISSING! its just NOT THERE!
i've ordered and is on its way, will probably get it by tuesday.
corrected the compressor wiring although it is not the original, took a speed sensor out of a denso compressor and completed the speed sensor circuit, everything works dandy now. the compressor doesn't engage without the speed sensor and it has to facing the pulley. I have connected a corolla's evap sensor for the time being, which doesn't trip the compressor at all
I'm now having problems with the HVAC controls, cooling and heating works, but the flaps that are controlled by the switchover valve aren't working properly, for instance when the knob is moved to the 'DOWN ARROW' position, it doesn't blow air to the footwell. it keeps blowing from the front center vents.
I checked the y11 vacuum switchover valve manually (by giving 12v to each solenoid, mine has four and all are working / opening and closing the valves as they should).
Could it be the N19 unit being problematic?
this is the one i have:
the wiring from the switchover valve to the n19 is good, confirmed them all using the wiring diagrams.. what else should I check?
