Pm me i will help you with it
@hassantahir2Hassan bhai waseem bhai ko thora sa help kar dain wo ab ye conpressor wapas krwa re hain our new compressor dalne ka soch re hain.... Ap ne jo new conpressor denso ka leya kaha se leya kya kharcha aya kese chala company fitted wala he tha ye sab zara explain kr dain....our suzuki company se new denso conpressor milta hai?
If u r in khi I can give u a v good AC service shop address near mukka chowk
I bought that Denso compressor in 2008 can't even remember the price now but that was somewhere around 14k RS that time. That compressor ran great for 5 year's but due to negligence of technician that died due to oil starvation i tried to get that repaired but failed as no one had new seals for that compressor otherwise internals of that compressor were in good shape. Have heard that new one is available from Suzuki for about 22k RS.In the end as always compressor isn't everything there are other components in AC system's and performance will also depend on them....
Hassan bhai kisi bahir shop se bhi mil skta hai denso ka genuine compressor cultus ka?
Yup should be available..
Cheaper? Kuch mene ye sunna hai kay jo wo. Denso lin gay us ma kuch alterations bhi krne parte hai pipes wagaira ki?
Yeah maybe cheaper than what dealership would be asking.Alterations depend on the system in car if it's a Denso system installed and you get the same replacement parts then no alterations needed. If you try to fit it in some other system that has some other type of compressor then there would be alterations like compressor bracket by which it is mounted on engine and the suction and discharge pipes on compressor.
@sayedgulhassan sayed bhai and @hassantahir2 hassan bhai thank you for sharing info
Try to find denso compressor which was already installed in your car when you purchased it from outside reputable ac shops or from pak suzuki if you have the bughet and as hassan bhai said do check the remaining parts of ac also... As you told me it is already checked by paksuzuki most probably you need genuine new compressor and good quality ac gas from well known ac mechanic or from paksuzuki if possible....
Your welcome, i will try to help you as much as i can... Now you have to take decisions wisely...
Whenever the compressor is cooked, it throws soot into the Condensor which should always be changed along with compressor with a Brand new part, not with some Kabli junk.
+1
Bhaiyon is bar jo bi change hona ha i will make sure ke wo component new hi ho warna wohi bat... Sasta roye bar bar mehanga roye ek bar
Change condensor and dryer bottle with brand new parts. Changing a burnt compressor without replacing the condensor and the dryer bottle will not get you anywhere.
Bhai if you are going for these components change then try to get a new Suzuki Baleno Multiflow condenser it fits perfect in Cultus and nothing needs to be altered for that. @RehanBhatti is using that Baleno condenser in his Cultus and someother PakWheelers have also tried that and that work's much better. I guess your location is Lahore there Fakhri brother's for part's and Punjab car AC are famous and Punjab car AC is also official distributor of Denso part's.
@ali454 sure bro that is the way to go now
@hassantahir2 bhai will there be a difference in cooling due to baleno condenser?
Yup the efficiency of the system will increase with a Multiflow condenser. The stock condenser is sprentine which doesn't work that well with R134a refrigerant.
A.O.A .bro i had cultus 2004 and than 2016 limited edition and i tried everything to achieve good cooling of ac but failed....even in limited edition when i used to park my car(no matter shed or sunlight) and used ac it didn't worked..i went to suzuki as well as to other some of the best technicians in multan everyone gave new opinion and ultimately a failure now i sold my limited edition cultus and switch to city and hàppy with my decision...
